Repeat control with Custom Control and Datasource
Hello,I’am developing a web XPages application, and I trying to use a techinique of using multiple Datasources suggested by John Mackey (http://www.jmackey.net/groupwareinc/johnblog/johnblog.nsf/d6plinks/GROC-7FFLYJ).
I gotta a main document that have 0 or more dependent documents. So, I desined a XPage with a repeat control that shows the associated documents:
<xp:repeat id=“repeat1” rows=“30” var=“entryExecutante”>
The formula that Im using inside the repeat control is:
xp:this.value<![CDATA[#{javascript:var arrayExecutante=null;
var index=0;
if(sessionScope.acaoVCP==“novoExecutante”){
arrayExecutante=new Array();
//arrayExecutante[index++]=sessionScope.dadosNovoExecutante;
arrayExecutante[index++]={
	action: null,
	NoteID: null,
	CodigoGerencia: vcp.getValue("ca_vcpCodigoGerencia"),
	CodigoVCP: vcp.getValue("ca_Codigo"),
	Gerencia: vcp.getValue("ca_vcpGerencia"),
	CodigoAN: vcp.getValue("ca_vcpCodigoAN")
var dc = viDu001.getAllDocumentsByKey(“C~”+vcp.getValue(“ca_Codigo”)+“~fo_ExecutanteVCP~”, false);
if(dc.getCount()>0){
if(arrayExecutante==null) arrayExecutante=new Array();
for(var i=1; i<=dc.getCount(); i++)
		NoteID: dc.getNthDocument(i).getNoteID(),
		action: vcp.isEditable()?"editDocument":"openDocument",
return arrayExecutante;}]]></xp:this.value>
Basically, this formula creates a array of objects that will initialize the custom control that contains the datasource of the associted doc.
At the beginning, I test if the user is creating a new document (sessionScope.acaoVCP==“novoExecutante”, this sessionScope variable is set through a button), if so, it sets the first position on the array with a object with action=null and NoteID=null, signaling that the datasource correspond a new document.
The button that shows that signals the repeat to put the empty custom control at the beggining follows:
<xp:button value=“Incluir Executante” id=“button5” styleClass=“customButton”>
<xp:this.rendered><![CDATA[#{javascript:vcp.isEditable() && sessionScope.acaoVCP!="novoExecutante"}]]>
</xp:this.rendered>
<xp:eventHandler event="onclick" submit="true" refreshMode="partial" immediate="true" refreshId="pnExecutantesForm">
	<xp:this.action>
		<xp:executeScript>
			<xp:this.script><![CDATA[#{javascript:sessionScope.acaoVCP="novoExecutante";}]]>
			</xp:this.script>
		</xp:executeScript>
	</xp:this.action>
</xp:eventHandler>
</xp:button>
Note that the event only tells the application to refresh partial, the “pnExecutantesForm” is the xp:panel that contains the button and the repeat control.
Inside the repeat, I put a custom control with a datasource to the associated document.
<xc:ccNovoExecutante
action="#{javascript:entryExecutante.action}"
CodigoAN="#{javascript:entryExecutante.CodigoAN}"
CodigoGerencia="#{javascript:entryExecutante.CodigoGerencia}"
CodigoVCP="#{javascript:entryExecutante.CodigoVCP}"
Gerencia="#{javascript:entryExecutante.Gerencia}"
NoteID="#{javascript:entryExecutante.NoteID}">
</xc:ccNovoExecutante>
This custom control provides a few properties to allow me to control its behavior.
The custom control’s Datasource is defined by the compositeData.action and the compositeData.NoteID:
<xp:this.data>
	<xp:dominoDocument var="docNewExecutante"
		formName="fo_ExecutanteVCP" ignoreRequestParams="true"
		computeWithForm="onsave"
		documentId="#{javascript:return compositeData.NoteID}"
		action="#{javascript:compositeData.action}">
		<xp:this.postNewDocument>
			<xp:executeScript>
				<xp:this.script><![CDATA[#{javascript:requestScope.CodigoNovoExecutante=@Unique()
docNewExecutante.replaceItemValue(“ca_exvCodigoGerencia”, compositeData.CodigoGerencia);
docNewExecutante.replaceItemValue(“ca_exvCodigoVCP”, compositeData.CodigoVCP);
docNewExecutante.replaceItemValue(“ca_Codigo”, requestScope.CodigoNovoExecutante)}]]></xp:this.script>
			</xp:executeScript>
		</xp:this.postNewDocument>
	</xp:dominoDocument>
</xp:this.data>
The main objective here is, allow the user to view the associated docs through this custom control in the main page, and, when the user clicks the button to add a new associated doc, the application shows in the first position a empty form to input the information.
THE PROBLEM:
When I click the button, instead of show a empty form, it shows a form whith the values of the last line of the associated docs, and scramble all the associated docs that it had already show in a correct way.
The strange thing is, when I put only the part of the code that put the object that intialize the custom control to show a empty form, it works. But, when I mixed up, it gets scramble.
I dont know what am I doing wrong.
Can anyone have a clue to work this out?
Subject: Workaround…
For those who are interesting, I figured out how to solve this “bug”.I put the object, that put the custom control as a “newDocument”, in the end of the array.
		<xp:repeat id="repeat1" rows="30" var="entryExecutante"
											disableTheme="true">
											<li>
												<xc:ccNovoExecutante action="#{javascript:entryExecutante.action}"
													Gerencia="#{javascript:entryExecutante.Gerencia}" NoteID="#{javascript:entryExecutante.NoteID}">
											</li>
											<xp:this.value><![CDATA[#{javascript:var arrayExecutante=null;
var index=0;
	arrayExecutante.push({
		action: (vcp.isEditable()?"editDocument":"openDocument")
		/*CodigoGerencia: dc.getNthDocument(i).getItemValueString("ca_exvCodigoGerencia"),
		CodigoVCP: dc.getNthDocument(i).getItemValueString("ca_exvCodigoVCP"),
		Gerencia: dc.getNthDocument(i).getItemValueString("ca_exvGerencia"),
		CodigoAN: dc.getNthDocument(i).getItemValueString("ca_exvCodigoAN")*/
// arrayExecutante=new Array();
	action: null,
	NoteID: null,
										</xp:repeat>
