Remote system no longer responding ! Second Post
Hi , This is my second post on this i have tried some suggestions in respond to my earlier post.
http://www-10.lotus.com/ldd/nd6forum.nsf/DateAllThreadedWeb/49B8BD1C0521592A85256FE400349E41?opendocument&login
But still i am getting this error.
I am still geting this" remote system no longer responding " error When my lotus client users from china are about to connect the “domain server” in hongkong.I am able to ping the domino server even the website on the domino server is opening without any problems.Users from other location are able to connect the domain server without any problem through the client.Only this location has the problem.
I have tried the following things
1)Clicked the “Trace” and selected ip address as well as the domino server name.But still i getting that error.
  1. Reinstalled the lotus client.
  2. Created the new connection document.
  3. Deleted the cache.
  4. Tried from other machine
  5. I have checked the status of port 1352 through nping.exe it is configured to the lotusnotes
This problem started on one machine and now all the machine are giving me the same error.
This used to never happen with lotus client 5.08 only this new version 6.5 is giving me this problem , This problem noramlly use to come earlier when ever a user switch ids but after some time the error used to stop , but this time the error is not going …i have tried the admin id also …
I have tried almost every thing but still i am not able to connect ,Trace log is as follows :-
Determining path to server Dss_NOTES/abc
Available Ports: TCPIP
Checking normal priority connection documents only…
Allowing wild card connection documents…
Checking for Dss_NOTES/abc at last known address ‘202.215.243.332’ on TCPIP…
Unable to connect to Dss_NOTES/abc on TCPIP (Remote system no longer responding)
No answer at last known address
Enabling name service requests and probes…
Checking for Dss_NOTES/abc on TCPIP using address ‘Dss_NOTES’
Unable to connect to Dss_NOTES/abc on TCPIP (The remote server is not a known TCP/IP host.)
Checking for Dss_NOTES/abc on LAN0 using address 'Dss_NOTES
Unable to connect to Dss_NOTES/abc on LAN0 (Remote system not responding)
Checking low and normal priority connection documents…
Local network connection document found for Dss_NOTES/abc
No default passthru server defined
Unable to find any path to Dss_NOTES/abc Group because Remote system no longer responding
My network structure :-
I am trying to connect to the my domino server through a adsl line .We have a router connected to the asdl line .The router is connected to the switch(hub).I have even connected one machine directly to the router but still that error keeps coming.
Is there some virus …or is that some antivirus problem which is not allowing users to connect to the domino sever,any suggestions will be greatfull.
Urgent help needed my users are not able to connect for three days now …help
Subject: Remote system no longer responding !! Second Post
So are you saying your china users have a server to connect to in China. Then that server has connection documents to your Honk Kong server?
If so then have you checked the basics:
A Firewall has not appeared in the middle and is blocking traffic from unknown ip’s?
Check a connection document exists between the relevant servers and see if they have hardcoded ip address’s that may have changed.
Check there is not an old Host file on your China server / users local machines that has old ip address’s in it.
If you rely on DNS, then check its not changed, use nslookup etc.
If the Honk Kong server is running smtp can you telnet to port 25 from your china location?
I would also check with your Network admins that nothing in the network route has changed.
Sorry I couldnt be more help.
Good luck.
Gaz
The trace log has the entry “No default passthru server defined” yet it sound like you need to use passthru to get from the China server to the Hong Kong server. Maybe you need to look at the server documents ???
Subject: RE: Remote system no longer responding !! Second Post
When we upgraded our Lotus Notes users in China from R5 to R6 they stopped being able to access our Domino servers in the US via Notes passthru. We discovered if we turned off port encryption it started working. Do you have the ports on the server or client encrypted?
