Rebuild unid index - compact -c
When i run compact -c on my mail boxes. I get this error on 2 of them.
Document NT000011B6 in database c:\x\mail\XX049129.TMP has been assigned a new UNID
Rebuild UNID index in database c:\x\mail\XX049129.TMP
then i run it again and it do the same execpt it says it another *.tmp file
Can anyone please help.
Subject: Rebuild unid index - compact -c
compact -c means that you compact your maildatabse into a new file. Meanwihle the compact is running, your mailfile is rebuild into a new file. It is the tempfile.
Do you have examined the Document with the ID NT000011B6? What type of Document is it?
Subject: RE: Rebuild unid index - compact -c
Sorry but how do i find a doc. with this id.
go ino your adminclient open the files view an use the tool search for document - right click on your maildb, choose the fourth entry from the bottom.
