We are having an issue with the ReadViewEntries URL command after our upgrade to 6.5.4. Previously on 6.5.3FP1 the ReadViewEntries command would return the right data but now it returns this:
<?xml version="1.0" encoding="UTF-8" ?>
I have tested it with the exact same dB on a 6.5.3 server and a 6.5.4 server with the same URL.
Is anyone else having this issue?
Subject: ReadViewEntries problem with 6.5.4
I’m having similar problems with notes 6.5.4. I’m requesting 10 documents from the mail nsf file using ?ReadViewEntries&start=505&count=10. There are times when 10 email documents are returned and other times when 0 to 9 are returned. The pattern I’ve noticed is it will work for about 5 minutes then stop working. Although it has worked for hours in the past so this is not a rule, just a pattern. The Notes server log is not showing “Recycle Bulk” when it fails. This issue is showing up on some users but not on others.
Does anybody have an idea on what I can look for to fix this issue?
The response is as follows
<?xml version="1.0" encoding="UTF-8"?>
