Hi all
Please accept my apologies if this is in the wrong place.
I’m in the middle of creating an auto-mailer via Excel VBA (and got most of it working) but I’ve run across a small(ish) snag.
To save me about 3 hours work, I need to get the following items:
To list
CC list
BCC list
Subject line
The message body text
Is there any way of getting VBA to read all the stationeries on our inbox (it’s shared) and giving me the info I need?
I currently have this code, but it’s not working :-
Sub test_reader()
Dim MailDbName As String
Dim Maildb As Object
Dim MailDoc As Object
Dim AttachME As Object
Dim Session As Object
Sheets("Sheet1").Select
Set Session = CreateObject("Notes.NotesSession")
MailDbName = "name.nsf"
Set Maildb = Session.GETDATABASE("CVNDM01", MailDbName)
If Maildb.IsOpen = False Then
Maildb.OPENMAIL
Set MailDoc = Maildb.createdocument
counter = 1
For Each stationery In Maildb
Range("A" & counter) = MailDoc.sendto
Range("B" & counter) = MailDoc.copyto
Range("C" & counter) = MailDoc.blindcopyto
Range("D" & counter) = MailDoc.Subject
Range("E" & counter) = MailDoc.body
counter = counter + 1
Next
'reset all objects to null
Set Maildb = Nothing
Set MailDoc = Nothing
Set AttachME = Nothing
Set Session = Nothing
Set EmbedObj1 = Nothing
