Volt IRIS supports reading and writing NFC tags. In this article we will cover how to read the NFC tags using IRIS application.
Create a Native app
Configure NFC for your project.
2.1. Add Android NFC capability.
Open Project Settings → select Native Tab → select Android Mobile/Tablet → In Manifest Permissions (Permission Tab) → add NFC and click Done.2.2 Add iOS NFC capability
Open Project Resources/common/quantum_nitro_configuration.json and add NFC entitlement.
2.3 Add NFC usage description for iOS
Open Project Resources/common/infoplist_configuration.json and add NFCReaderUsageDescription key and value. -
Add a button to Form
Drag and drop the button widget and change text to “Read Tag”. -
Add function to FormController
4.1. check NFC availability in device
if (voltmx.os.hasNFCSupport()) {
//call NFC API's
} else {
alert("NFC is not Supported in this device");
4.2 start scan session and configure success and error call backs.
var errorCallback = function(error){
if(error.errorCode === voltmx.nfc.ERROR_NO_TAG){
alert("Tag no longer nearby to read.");
var success = function(tags){
if(tags!==undefined && tags.length>0){
if(tags.length===1){
//read data from tag or write data to tag
else {
var update = {"message":
"More than 1 tags found. Please present only 1 tag."};
voltmx.nfc.updateUI(update);
var config = {
"scanContinuously": false,
"message" : "Hold your device near an NFC tag."
voltmx.nfc.scanTag(config, success, errorCallback);
The expected screen on device(iOS):
4.3. call readData API to read the data records of the NFC Tag.
var readSuccessCallback = function(tagData){
//show/save tagData
tags[0].readData(readSuccessCallback, errorCallback);
4.4. show/save Tag records and then stop scan
var result = JSON.stringify(tagData);
voltmx.nfc.updateUI({"message": "Tag read success."});
voltmx.nfc.stopScan();
alert(result);
Note: You can copy the following complete function to your controller.
readTagRecords: function ()
alert(result);
else {
var update = {"message": "More than 1 tags found. Please present only 1 tag."};
var config = {
} else {
alert("NFC Support is not available in this device");
Map function to the button click in action editor.
Build and Run the app.
Note: Tap or reach the NFC tag to see tag data.
Documentation of all the NFC API’s can be found here.
