Read MS Word using LotusScript
We have a Word Form with defined fields that is sent to a customer & returned filled in. We would like to be able to access the Word doc from within Notes (LotusScript) and update database fields. I’ve found how to open the Word doc as a Word application object but can’t seem to find any documentation anywhere that defines the objects/properties/methods of a Word doc. I’ve found examples how to create/write to a Word doc, but not how to access fields (bookmarks) from one. Any help would be greatly appreciated.
Subject: Read MS Word using LotusScript
Try this link or search for MS WORD Document Object Model
Subject: Getting values fromFields, FormFields and Bookmarks
Hi
Here is a quick example of an agent that checks if a word document is protected and then looks for a Field(bookmark), a customDocumentProperty, and a FormField
Hope this helps
Tim
Dim ActiveDocument As Variant 'Global
Sub Initialize
Dim fileName As String
fileName = "h:\myWordDoc.doc"
Set activeDocument = GetObject(fileName, "Word.Document")
activeDocument.Application.Visible=True
'ensure the document is unprotected (if you can). Working with protected documents can be alot of fun
If activeDocument.ProtectionType <> -1 Then
	Msgbox ("This document is protected, please unprotect and try again")
end
'Check for fields (defined by bookmarks)
If activeDocument.Bookmarks.Exists("MyField") = True Then
	activeDocument.Bookmarks("MyField").Select
	fval= activeDocument.ActiveWindow.Selection.Range.Text
Else
	Msgbox ("Could not find bookmark for MyField")
'Check for custom props
If CustomPropertyExists("MyProperty") Then
	cVal = activeDocument.CustomDocumentProperties("MyProperty").Value
Else
	Msgbox ("Cannot find property myProperty")
'Check for FromFields
If FormFieldExists("myField") Then
	mVal = activeDocument.FormFields("myField").Result
Else
	Msgbox ("Cannot find Form Field myField")
Function CustomPropertyExists(CustomPropertyName As String) As Boolean
CustomPropertyExists=False
Forall propCustom In ActiveDocument.CustomDocumentProperties
	If propCustom.Name = CustomPropertyName Then
		CustomPropertyExists=True
		Exit Function
End Forall
End Function
Function FormFieldExists(FormFieldName As String) As Boolean
FormFieldExists=False
Forall aField In ActiveDocument.FormFields
	If aField.Name = FormFieldName Then
		FormFieldExists=True
		Exit Function
End Forall
End Function
Subject: Getting values from Fields, FormFields and Custom Properties
This might be better for getting the value out of a field
If activeDocument.Bookmarks.Exists(“MyField”) = True Then
activeDocument.Bookmarks(“MyField”).Select
fval= activeDocument.ActiveWindow.Selection.Range.Fields(1).Result
Else
Msgbox (“Could not find bookmark for MyField”)
You can record a Word macro and then examine the code there. With small changes the macro code can be used in LotusScript.
I have some example of using Excel object from LotusScript, but not Word: Botstation - Code Vault
