Subject: read mails turns in to red (unread) after replying.
Go into the database properties and on the fourth tab along (the design tab that looks like a set square) put a tick in the box that says “Do not mark modified documents as unread”.
Louise.
Subject: RE: read mails turns in to red (unread) after replying.
If user has this problem and the value is already checked, uncheck, recheck and you should be good to go. I have had a single user who had this problem after 6.5.4 install and this took care of the problem.
