Re: Will Easysync 4.2.5 work with wm6?
Has anyone experienced with Easysync 4.2.5 and wm6? I just got my new ppc device with wm6. Therefore, I’m not sure if Easysync 4.2.5 will support wm6 or not.
Your advice will be highly appreciated.
Thanks.
Subject: Re: Will Easysync 4.2.5 work with wm6?
Hello,
Just tried here with version 4.2.4 and my Asus P535 that I upgraded to WM6, works fine, so it should work fine with 4.2.5 too.
But don’t install the easysync module on the SD card (WM6 asks where you want to install it) or it fails when you try to synchronize.
