RCP Base plug-in Not found when using smart upgrade for 8.5.1
When upgrading from Lotus Notes 8.5 to 8.5.1 using Smart Upgrade tool I get the following error when I am trying the silent install to install the Single Client Login component.
Using the smart upgrade database I have it pointing to a network share and the following optional arguments are being used.
/v"ADDLOCAL=ClientSingleLogon /lv* c:\temp\install.log SETMULTIUSER=1 SELECTINSTALLFEATURES=SametimeUI /qb+!"
All on one line the result is the user is prompted to upgrade the start the upgrade and part way through the install this error message “RCP Base plug-in not found” is the result
If I use the exact same process and I change the arguments to take out the clientsinglelogon part the install works fine.
/v"/lv* c:\temp\install.log SETMULTIUSER=1 SELECTINSTALLFEATURES=SametimeUI /qb+!"
Using the optional argument line gives a successful install but no client single logon is installed.
If I move the optional arguement to a different part of the line like this:
/v"/lv* c:\temp\install.log SETMULTIUSER=1 ADDLOCAL=ClientSingleLogon SELECTINSTALLFEATURES=SametimeUI /qb+!"
Same error results.
Anyone have any ideas where to place this in the arguement line I found the clientsinglelogon part from the following website.
http://www-01.ibm.com/support/docview.wss?rs=475&context=SSKTWP&dc=DB520&dc=DB560&uid=swg21287212&loc=en_US&cs=UTF-8&lang=en&rss=ct475lotus
If anyone can help with this so I can make the silent install include the Client single logon that would be wonderful.
thanks for your time
Shawn
Subject: Fwd to development
install/AS
