Radio Button number of columns problem
I am attempting to create a survey form with radio button choices ranging from 1 to 10. Unfortunately Notes allows 8 columns. Has anyone else encountered this and is there some known work around? I attempted 2 fields (1-5) and (6-10) but I need a way to deselect the choices in one field if choices are made in another.
any clues would be greatly appreciated.
Subject: So use two rows of five choices each
Subject: RE: So use two rows of five choices each
I already did try that but the problem is keeping preventing the user from selecting an item from each of the fields of 5 choices.
What I am looking to do is have a survey with choices 1 -10 with radio buttons as the choices. The request is to have all options on one line. Since Notes limits the number of radio button columns to 8 - you can only have 1-8 in this fashion. I have attempted to split the fields - 1-5 and 6-10. The problem is allowing only one choice of these possible 10 (across 2 fields) to be selected. Ultimately - the struggle I am having is to set up an event that sets the value of the one field to “” when anything is selected from the other field.
I guess I am just trying to find some piece of code that would change the value in one field when a selection is made in the other field - and vice versa.
I believe that what was suggested was to use one field, set the columns to 5 and let it wrap to two rows.
Subject: Radio Button number of columns problem
Are u looking at web or client?If web: use a normal text field for the value, hide it and do some passthru html to show the 10 radio buttons.
However: bad design! Radiobuttons with a horizontal layout tend to confuse users a lot (culture dependend question: is the radio in front or after the text valid). Try some clickable table in JavaScript (updating the hidden value) instead
Hth
:slight_smile: stw
