R6 ~ Creating a Web Application Fundamental Problem
Guidence sought . . Please?
I am creating a trial web application and limiting myself to Commands and Functions and an assumption that the user will not have Java Applications able to run ~ which is “working fine” so far.
My main sticking points are:
URL Commands:~ I can control the start and quantity of items to display in a view BUT I cannot capture “where I am”, to influance a Next / Previous . . so that they do not appear imappropriately.
EXPORTS : I wish to cause an email or download of a view as a spreadsheet but cannot find guidance.
I am wondering if there is a more basic sample site / practical tutorial / book which may give me some opportunity to try things out?
Any help greatly appreciated.
THANKS
Simon
Subject: R6 ~ Creating a Web Application Fundamental Problem
http://www.codestore.net/store.nsf/unid/EPSD-66GGUM?OpenDocument
Subject: RE: R6 ~ Creating a Web Application Fundamental Problem
HiFollowed the link, did the research and answered my questions.
Thank you very kindly indeed.
Best wishes
Simon
Simon:
For your first question:
NavigateNext and NavNext
The NavigateNext and NavNext @commands open the next document in the current view or folder.
@Command([NavigateNext])
or
@Command([NavNext])
For Web applications, you can only use these @commands on forms; you cannot use them in views or folders.
These @commands are equivalent to a URL command formatted as follows:
http://host/database/universalID?OpenDocument
Issue on the web is that the web page has no concept of a cursor, like a notes view, so you’re not anywhere in the view when displayed on the web.
As to your second question, if you mean export from a web page to an excel file, check codestore.org for a clever idea
HTH
Don
Thanks very much, Donald
That got me pointing in the right direction and “problem” solved. Until the next time.
Best wishes
Simon
