"Prompt for Location" acting odd
Hi all,
We are running Notes 6.0 without the Notes Single Sign On Feature installed. Instead, we use a 3rd party password synchronization/single sign on product. For our laptop users, we have added the “PROMPTFORLOCATION=1” entry in the notes.ini. Now, some users are reporting that no matter which location they select when prompted, Notes always starts using the last location that was in use. So if you exited in Island mode and then restart and select “Office” at the prompt, you still start in Island mode.
Has anyone else seen behavior like this? If so, where you able to solve the problem?
Many thanks for your help
