Hi
when user click on find button user’s profile page shoul be open. In normal conditions it is working properly. But if 2 or more users try to open their profiles at same instance of time, they are getting other’s profiles. Means only one profile is opening to all the users.
I am not understand why this is happening.
Can any one help me.
Subject: problems with web application
Hi Pradeep
To get help in this forum you need to do 2 things “well”:
1- make the subject of your post very specific to the probelm area. This way forum members who are experts in that area will look (& any others will not waste their time) otherwise you get a lot less people reading your post. For example:
Only one profile document opens for multiple users!
or
Problem opening correct profile documents.
2- Provide more technical details. In this case add the button code to your message so experts can see if the problem is with the code or somewhere else. make sure anyone reading the code and your message has enough information to help you.
Also please check the forum guidance notes “Forum use and etiquette” (on the right hand side of the page) which will help you get the most from this forum.
I suggest you post a new message with the above details included. But please monitor this thread as well in case someone else wants to discuss the problem with you.
Good luck
B
http://www.Internet-Marketing-Wizards.com
Etiquette counts, of course, but since you’ve already been properly chastised I don’t need to add more.
Are you using servlets? If so, I would check to see if the servlet has the user, or the user’s profile, as member data. All users of the one instance of the servlet have access to its member data, which would be one way to produce the behavior you describe.
If that’s the problem, you might consider storing user specific data in the request or session objects.
Good Luck!
-sl
