Hi everybody,
I can't get OpenSearch to work in Component Pack 8. I'm installing it manually (not via Ansible) to learn the in and outs of the new version. I installed CP 7 and previous versions this way. I'm using all the recommended versions of software for my Kubernetes Cluster on RedHat 7.9.
The problem is with TLS and the private key, that OpenSearch is trying to use. It gets created with the "bootstrap".
Here is the error in the Master Pod:
[2023-01-17T09:38:24,544][ERROR][o.o.b.OpenSearchUncaughtExceptionHandler] [opensearch-cluster-master-0] uncaught exception in thread [main]
org.opensearch.bootstrap.StartupException: java.lang.IllegalStateException: failed to load plugin class [org.opensearch.security.OpenSearchSecurityPlugin]
at org.opensearch.bootstrap.OpenSearch.init(OpenSearch.java:182) ~[opensearch-1.3.0.jar:1.3.0]
at org.opensearch.bootstrap.OpenSearch.execute(OpenSearch.java:169) ~[opensearch-1.3.0.jar:1.3.0]
at org.opensearch.cli.EnvironmentAwareCommand.execute(EnvironmentAwareCommand.java:100) ~[opensearch-1.3.0.jar:1.3.0]
at org.opensearch.cli.Command.mainWithoutErrorHandling(Command.java:138) ~[opensearch-cli-1.3.0.jar:1.3.0]
at org.opensearch.cli.Command.main(Command.java:101) ~[opensearch-cli-1.3.0.jar:1.3.0]
at org.opensearch.bootstrap.OpenSearch.main(OpenSearch.java:135) ~[opensearch-1.3.0.jar:1.3.0]
at org.opensearch.bootstrap.OpenSearch.main(OpenSearch.java:101) ~[opensearch-1.3.0.jar:1.3.0]
Caused by: java.lang.IllegalStateException: failed to load plugin class [org.opensearch.security.OpenSearchSecurityPlugin]
at org.opensearch.plugins.PluginsService.loadPlugin(PluginsService.java:792) ~[opensearch-1.3.0.jar:1.3.0]
at org.opensearch.plugins.PluginsService.loadBundle(PluginsService.java:728) ~[opensearch-1.3.0.jar:1.3.0]
at org.opensearch.plugins.PluginsService.loadBundles(PluginsService.java:530) ~[opensearch-1.3.0.jar:1.3.0]
at org.opensearch.plugins.PluginsService.<init>(PluginsService.java:193) ~[opensearch-1.3.0.jar:1.3.0]
at org.opensearch.node.Node.<init>(Node.java:396) ~[opensearch-1.3.0.jar:1.3.0]
at org.opensearch.node.Node.<init>(Node.java:319) ~[opensearch-1.3.0.jar:1.3.0]
at org.opensearch.bootstrap.Bootstrap$5.<init>(Bootstrap.java:242) ~[opensearch-1.3.0.jar:1.3.0]
at org.opensearch.bootstrap.Bootstrap.setup(Bootstrap.java:242) ~[opensearch-1.3.0.jar:1.3.0]
at org.opensearch.bootstrap.Bootstrap.init(Bootstrap.java:412) ~[opensearch-1.3.0.jar:1.3.0]
at org.opensearch.bootstrap.OpenSearch.init(OpenSearch.java:178) ~[opensearch-1.3.0.jar:1.3.0]
... 6 more
Caused by: java.lang.reflect.InvocationTargetException
at jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) ~[?:?]
at jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62) ~[?:?]
at jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45) ~[?:?]
at java.lang.reflect.Constructor.newInstance(Constructor.java:490) ~[?:?]
at org.opensearch.plugins.PluginsService.loadPlugin(PluginsService.java:783) ~[opensearch-1.3.0.jar:1.3.0]
... 6 more
Caused by: org.opensearch.OpenSearchSecurityException: Error while initializing transport SSL layer from PEM: java.lang.IllegalArgumentException: File does not contain valid private key: /usr/share/opensearch/config/certs/opensearch-transport.key
at org.opensearch.security.ssl.DefaultSecurityKeyStore.initTransportSSLConfig(DefaultSecurityKeyStore.java:419) ~[?:?]
at org.opensearch.security.ssl.DefaultSecurityKeyStore.initSSLConfig(DefaultSecurityKeyStore.java:258) ~[?:?]
at org.opensearch.security.ssl.DefaultSecurityKeyStore.<init>(DefaultSecurityKeyStore.java:179) ~[?:?]
at org.opensearch.security.ssl.OpenSearchSecuritySSLPlugin.<init>(OpenSearchSecuritySSLPlugin.java:218) ~[?:?]
at org.opensearch.security.OpenSearchSecurityPlugin.<init>(OpenSearchSecurityPlugin.java:252) ~[?:?]
... 6 more
Caused by: java.lang.IllegalArgumentException: File does not contain valid private key: /usr/share/opensearch/config/certs/opensearch-transport.key
at io.netty.handler.ssl.SslContextBuilder.keyManager(SslContextBuilder.java:386) ~[?:?]
at io.netty.handler.ssl.SslContextBuilder.forServer(SslContextBuilder.java:120) ~[?:?]
at org.opensearch.security.ssl.DefaultSecurityKeyStore.buildSSLServerContext(DefaultSecurityKeyStore.java:869) ~[?:?]
at org.opensearch.security.ssl.DefaultSecurityKeyStore.initTransportSSLConfig(DefaultSecurityKeyStore.java:405) ~[?:?]
... 6 more
Caused by: java.security.spec.InvalidKeySpecException: Cannot retrieve the PKCS8EncodedKeySpec
at javax.crypto.EncryptedPrivateKeyInfo.getKeySpec(EncryptedPrivateKeyInfo.java:258) ~[?:?]
at io.netty.handler.ssl.SslContext.generateKeySpec(SslContext.java:1090) ~[?:?]
at io.netty.handler.ssl.SslContext.getPrivateKeyFromByteBuffer(SslContext.java:1144) ~[?:?]
at io.netty.handler.ssl.SslContext.toPrivateKey(SslContext.java:1123) ~[?:?]
at io.netty.handler.ssl.SslContextBuilder.keyManager(SslContextBuilder.java:384) ~[?:?]
... 6 more
Caused by: javax.crypto.BadPaddingException: Given final block not properly padded. Such issues can arise if a bad key is used during decryption.
at com.sun.crypto.provider.CipherCore.unpad(CipherCore.java:975) ~[?:?]
at com.sun.crypto.provider.CipherCore.fillOutputBuffer(CipherCore.java:1056) ~[?:?]
at com.sun.crypto.provider.CipherCore.doFinal(CipherCore.java:853) ~[?:?]
at com.sun.crypto.provider.PKCS12PBECipherCore.implDoFinal(PKCS12PBECipherCore.java:408) ~[?:?]
at com.sun.crypto.provider.PKCS12PBECipherCore$PBEWithSHA1AndDESede.engineDoFinal(PKCS12PBECipherCore.java:440) ~[?:?]
at javax.crypto.Cipher.doFinal(Cipher.java:2202) ~[?:?]
at javax.crypto.EncryptedPrivateKeyInfo.getKeySpec(EncryptedPrivateKeyInfo.java:253) ~[?:?]
... 6 more
Likely root cause: javax.crypto.BadPaddingException: Given final block not properly padded.
at java.base/com.sun.crypto.provider.CipherCore.unpad(CipherCore.java:975)
at java.base/com.sun.crypto.provider.CipherCore.fillOutputBuffer(CipherCore.java:105
at java.base/com.sun.crypto.provider.CipherCore.doFinal(CipherCore.java:853)
at java.base/com.sun.crypto.provider.PKCS12PBECipherCore.implDoFinal(PKCS12PBECipher
at java.base/com.sun.crypto.provider.PKCS12PBECipherCore$PBEWithSHA1AndDESede.engine
at java.base/javax.crypto.Cipher.doFinal(Cipher.java:2202)
at java.base/javax.crypto.EncryptedPrivateKeyInfo.getKeySpec(EncryptedPrivateKeyInfo
at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native
at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(NativeCo
at java.base/jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(Dele
at java.base/java.lang.reflect.Constructor.newInstance(Constructor.java:490)
<<<truncated>>>
The private key looks good to me:
"opensearch-transport.key": "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"
Did anybody else have a similiar problem or a solution for this?
I tried a few things already, but always ended up with the same error.
Florian
