I am trying to setup OpenSearch pods. I started with "Opensearch-Master" after initializing connections-env, volumes, etc...I am using the following command to install:
helm upgrade opensearch-master v-connections-helm/opensearch -i --version 1.3.7-20230117-205850 --namespace connections -f opensearch_master.yml
opensearch_master.yml:
image: repository: hclcr.io/cnxclusterName: opensearch-cluster
nodeGroup: “master”
masterService: “opensearch-cluster-master”
pemkeyPass: locarno2023
imagePullSecrets:
- name: myregkey
roles:
- master
service:
labels: {}
labelsHeadless: {}
type: NodePort
nodePort: 30099
nodePortTransport: “”createSecret: false
resources:
limits:
cpu: “1”
memory: “1024Mi”
requests:
cpu: “0.1”
memory: “768Mi”
replicas: 3
"kubectl logs" does not work because pod is still not initialized "Init:CrashLoopBackOff".
"kubectl events -A" :
connections 9m11s Normal Created pod/opensearch-cluster-master-2 Created container fsgroup-volume
connections 9m11s Normal Started pod/opensearch-cluster-master-2 Started container fsgroup-volume
connections 8m29s Normal Pulling pod/opensearch-cluster-master-2 Pulling image "busybox:latest"
connections 8m28s Normal Pulled pod/opensearch-cluster-master-2 Successfully pulled image "busybox:latest" in 902.247168ms (902.270348ms including waiting)
connections 8m23s Normal Pulling pod/opensearch-cluster-master-0 Pulling image "busybox:latest"
connections 8m18s Normal Pulling pod/opensearch-cluster-master-1 Pulling image "busybox:latest"
connections 5m2s Warning BackOff pod/opensearch-cluster-master-0 Back-off restarting failed container
connections 4m57s Warning BackOff pod/opensearch-cluster-master-2 Back-off restarting failed container
connections 4m45s Warning BackOff pod/opensearch-cluster-master-1 Back-off restarting failed container
ES5 & ES7 worked smoothly on this Kubernetes-Host(all-in-one deployment, only master). Since I have much less parameters to provide with CP8 & everything is in an online-repo I was wondering: What have I done wrong ? Why is the OS-master-pod not starting ?
Any help/ideas appreciated.
I am already in contact with HCL but no progress - I hope the community can provide some additional input.
Many thanks in advance !
Kind regards,
Jan
