Problems with acces & delegation will not update
I’m having problems with one specific user who wants to give access to other users (access & delegation) on her mailfile.
When closing the mailfile the default rights (which are deleted) will return also the addition is gone.
How can I solve this.
Rudy
Subject: Problems with acces & delegation will not update
When I give the user manager rights it works fine, but that isn’t what I want.
Subject: RE: Problems with acces & delegation will not update
check whether the ACL setting of admin4.nsf is correct default should have author access
yes this is correct, only 2 users have this problem
Is the user who wants to give delegation going through the prescribed steps to do so? If so, there are some preliminary things to check: 1. make sure the mail file owner information (under tools in the inbox view) of the person who wants to give delegation rights is correct. 2. check the location document and make sure all the information is correct there as well. 3. check the user’s ACL rights to their own mail file (I have seen delegation fail if the user trying to grant delegation does not have manager access to their own mail file). Adding the delegate’s name to the ACL manually is not the way to go about giving delegation rights as you seem to already know.
