Problems sending pictures in the body of e-mail
I am trying to write a mass e-mail agent to send promotional e-mails to our donors.The e-mail contains pictures and links.
All these e-mails are internet e-mails.
When I send the e-mail just from my regular inbox manually to my internet address everything looks fine and everything works OK. The moment when I use an agent to send the e-mails it changes the format of the e-mail and puts all the pictures into attachments.
I am using this script:
Call memo.Send(False)
I think it has something to do with the MIME settings, but I have no idea how to fix this.
Can somebody please help me?
Thank you
Subject: Problems sending pictures in the body of e-mail
Are you putting the images into a richtext field in the document you send?
Shawn
Subject: RE: Problems sending pictures in the body of e-mail
Yes. One of the images is also a link to a web site.
Can you post the script?
Shawn
Actually I figured it out. In the “Memo” form I’ve changed the properties of the “Body” field - the Contol tab - Storage - Store contents as HTML and MIME
But thanks for your help anyway
