I am trying to have the following agent run as a querywebsave agent, but when I do nothing happens (document does not get saved and the agent does not run). I don’t even get the ‘Document Processed’ message, it just goes to the default webpage for the application. I have done this a zillion times but I cannot figure out WHY it is not working this time!!! Help…And I know it has something to do with the agent because ifI don’t call it from the webquerysave, the document gets saved.
Form has 2 fields, lastname and netid (simplified to the barebones to try to resolve this issue) and submit button with a filesave and fileclosewindow command
agent = welcome
trigger = action menu selection
webquery save on the form has @Command([ToolsRunMacro]; “welcome”)
And the agent looks like this
Sub Initialize
Dim s As New NotesSession
Dim memo As NotesDocument
Dim note As NotesDocument
Dim db As NotesDatabase
Set db = s.CurrentDatabase
Set note = s.DocumentContext
Set memo = New Notesdocument(db)
If note.netid(0) <> "" Then
memo.Form = "Memo"
memo.Principal="xxxx@uic.edu@NotesDomain"
memo.SendTo = note.netid(0)
memo.MailOptions = "1"
memo.Subject = "Welcome to UIC's FaCT Computer Program "
tmpstring = "Hello, " + note.lastname(0)
paragraph1 = " paragraph1"
paragraph2 = "paragraph2"
paragraph3 = "paragraph3"
paragraph4 = "paragraph4"
paragraph5 = "Thank you"
paragraph6 = "--- xxxx@uic.edu"
paragraph7 = " http://myurl"
Set memobody = memo.CreateRichTextItem("Body")
Call memobody.AppendText(tmpstring)
Call memobody.Addnewline(2)
Call memobody.AppendText(paragraph1)
Call memobody.AppendText(paragraph2)
Call memobody.AppendText(paragraph3)
Call memobody.AppendText(paragraph4)
Call memobody.AppendText(paragraph5)
Call memobody.AppendText(paragraph6)
Call memobody.AppendText(paragraph7)
Call memo.Send(False)
note.newfaculty="no"
Call note.save (False,False)
The agent runs fine if I run it against an existing document in the DB from the actions menu.
What am I doing wrong? This is driving me crazy!
Thank you in advance
Cynthia
