I have a wildcard certificate for my domain used for company web server (IIS7).
I want to import this certificate to domino in order to use SSL when our users access their email.
On the internet I found a lot of documentation but none of them helped me to solve the problem.
Basically I started with the guide from turtleweb http://www.turtleweb.com/turtleblog.nsf/dx/11022009232215GDAVGR.htm?opendocument&comments http://www.turtleweb.com/turtleblog.nsf/dx/11022009232215GDAVGR.htm?opendocument&comments .
My questions:
- is there any program other that very old (and unusable on modern certificates) gsk5-ikeyman which properly works with IBM .kyr keyring container? My certificate is Keylength: 2048, signature algorithm:SHA256RSA from Geotrust and what i found after a lot of tests is that gsk5-ikeyman does not support SHA256. The majority of internet certifiers now switched to sha256 signature. The newer versions of ikeyman does support SHA256 but doesn’t know how to handle .kyr container.
Anyway I loose a lot of time trying to resolve this problem and it’s frustrating.
Please help with any ideas…
Regards,
Adrian
