Problem with WebCam and Cache
Hi all,
I’ve just setup my new webcam, and wanted to create a little website where there’s an image that got updated every 2 seconds.
I downloaded a little program (pjWebCam) to capture an image and save it every 2 seconds to a locally mapped drive (W:). This mapped drive is actually a folder in my file-structure on my webserver (6.0.1) and I’ve created a little page that use a Java applet to refresh the picture every 2 seconds…
Heres the problem:
The picture dosn’t change. I know that the webpage resfreshes, and I know that the JPEG file gets overwritten with a new one every 2 seconds (using a pictureviewer I can see that it changes).
I believe that the problem is in the Image and File cache on the Domino server. I’ve tried to change the ‘Maximum cache size’ from the default 50 Mb to 0 Mb. This didn’t help… The picture still dosn’t update. Not even when I make a forced browser refresh (CTRL+F5 in IE).
Does anyone have any advice?
Kind regards,
Hans
Denmark
Subject: Problem with WebCam and Cache
You can enforce browser refresh with a web header rule
Add these headers via a header document under your website document
Expires 0
Cache-Control No-Cache
for the URL of your picture
Subject: RE: Problem with WebCam and Cache
Hi Michael
I’ve tried what you suggested, but it still dosn’t seem to work. If I close my browser, and start it again, it loads the newest picture, but when the applet refreshes the image, its the same that’s loaded (eventhough it been replaces with a newer).
Any other ideas that I might try out?
Hello Hans,
I am also trying to create a webcam. We hade the same problems. There are 4 meta tags you must enter.
this din’t do the complete job for IE. there for we used the folowing code to trick IE.
image.src = “http://…Image17_0_1.jpg?” + new Date().getTime(); (javascript).
This worked here.
But we have a problem chekking if the image (on disk) is available. How did you solve that?
