Problem with ToolsMarkSelectedUnread command
I am using @Command([ToolsMarkSelectedUnread]) just after saving the document with @Command([FileSave]) command but I don’t get the desired result.
The only condition given (in the notes documentation) is that either the view should be open with the document(s) selected or the document itself should be open in read/edit mode.
So, in my case the second condition applies.
Any solutions to this problem? I need this urgently.
Note:- all my view settings(for showing unread marks)are fine.
TIA
  • Shiva
