Problem with subscriptions: "Monitor has already been registered"
Hello,
I hope my english is not to bad, because this problem is quite difficult to explain.
We used successfully subscriptions with Notes5 /Domino 5 during a long time.
Problems appeared when we upgraded our server to V6.5
At first, no updates appeared in the headline.nsf, while new documents had been created in our database.
I deleted in headline.nsf the subscription document and created a new subscription in our database.
Then appeared in the subscription status view colum the following error message : “Monitor already registered, no action taken”.
I tried to delete headline.nsf in order to start from scratch, but the problem remains the same.
I noticed something that is very queer : whenever I delete the headline.nsf and restart my client, a new headline.nsf is created and some time later, subscriptions documents (the same I erased before) appear in the headline.nsf database, without me doing anything, and the status remains the same (monitor already registered).
I upgraded the client to 6.5 : it changes nothing
I upgraded our database format to V6 : it changes nothing.
I have no more idea : I can’t figure our how subscriptions documents can’t be created, without me doing anything, in headline.nsf, which is a local database !
As somebody a tip ?
Thank you.
Subject: problem with subscriptions: “Monitor has already been registered”
I can’t provide a solution to your problem, but I can tell you we’ve been experiencing the same thing for more than 6 months with nothing more than the following from Lotus:
On 10/31/03, we were told the relevant SPR is DHAN5RGUNG. Note that I’ve never found any information on this SPR, and that I can only assume it is still unresolved, since they haven’t called to tell us otherwise, as promised.
I still have the very same problem an questions as Jean-Philippe and Steven today, even though I’m running 7.0 client and 6.5.4 server./Pierre
Subject: RE: problem with subscriptions: “Monitor has already been registered”
Does not surprise me since the mail rules run on the server, not the client.
