Problem with starting Prometheus for Sametime monitoring
Hello,
We have active monitoring with Grafana (part of Sametime) on Sametime server V12.0.1 FP1 (Docker). Grafana has its own strore, so no reconfiguration is needed after restart Sametime server..
Unfortunately, after a restart of the Sametime server or reboot OS, Grana will not start properly because the Prometheus container will not start.
You need to remove the directories that are missing the "chunks" folders that Prometheus has stored in the tmp/prometheus/data folder.
This is the same problem: https://support.hcltechsw.com/csm?id=kb_article&sysparm_article=KB0103125
Has anyone encountered this and has a tip on how to fix it to avoid the above problems and not have to manually delete and start the Prometheus container?
Thank you
Ales
