Problem with Simplified Chinese email
Dear all expert,
I’ve a big problem!! My current config as follow:
OS : Chinese Windows XP
Lotus Notes : Chinese Lotus Notes 6.5.1
The problem is that I can’t read those email from china (ie. using Simplified chinese)
I’ve tried to modify the windows XP - Regional setting (advanced tab → choose PRC for non-unicode program). With this setting, I can read those simplified chinese email, but other chinese application program was changes (to other char.)
I’ve also tried to use View → Encoding → Simplified for that email, but still can’t work.
Pls help and Big Thanks in Advance.
Regards
Raymond
Subject: Problem with Simplified Chinese email
Hi Raymond,There are fonts come with the Notes CD. Install at least the Monotype Sans WT TC in Windows
Make use of the font in Notes by:
File → Preferences → User Preferences
Select Default Fonts on the Basic tab
Set them all to the above
After restarting Notes, Simplified Chinese can be displayed.
Regards,
KP
Subject: RE: Problem with Simplified Chinese email
Is it same if I using LN on MAC OS ?
Would you mind send me the ( .tff) to try it out ?
Many thanks,
happylee@e-solution.com.hk
Or set font to Dotum if you can find it.
I did try to set Dutum, it works a few mail but doesn’t work the others. Any other ways I can try?
thanks,
Kenny.
