Problem with searching images from view
I am having problem in searching images.I have uploaded the image and saved it.The image is saved as a document in view.But if the user wants to search for the image with a particular extension.for e.g. jpeg,bmp.How can the desired images would be uploaded??Send me only code
Subject: problem with searching images from view
thanks andre
Subject: RE: problem with searching images from view
You have not specified the problem in enough detail for code to be written.
The @AttachmentNames function will return a list of the names of attached files, including the suffix. You can use this in a formula in a view column to categorize documents by their file suffix.
If you want to do a full-text search for “gif” (for instance), I’m not sure whether the filename is indexed; you could try it and see. If not, add a computed field that uses @AttachmentNames in its formula so that the filenames will be indexed, and then a full-text search will work.
