This script resides on an action button in the inbox. It loops through all selected docs in the inbox and gives the file save prompt box. It defaults in the subject line as the file name, and if multiple selections it will remember last saved directory for the next. The files are saved as .ndl format.
The script works fine up to two selections, but not more than that. I’ve narrowed the problem to using the email subject as the filename - if I use a default of say “test.ndl” it works fine. I thought of invalid characters in the subject, but the results are the same no matter which two emails are first.
Any ideas?
Thanks,
William
Sub Click(Source As Button)
Dim uiview As NotesUIView
Dim db As NotesDatabase
Dim repid_db$
repid_db$ = Left$(db.ReplicaID, 8) + “:” + Right$(db.ReplicaID, 8) ’ format dbase replica id
’ use all docs view for .ndl retrieval
Dim alldocs As NotesView
Dim unid_alldocs$
Set alldocs = db.GetView(“($All)”)
’ format unid for all docs view
unid_alldocs$ = “OF” + Left$(alldocs.UniversalID, 8) + “:” + Mid$(alldocs.UniversalID, 9, 8)_
- “-ON” + Mid$(alldocs.UniversalID, 17, 8) + “:” + Right$(alldocs.UniversalID, 8)
Dim dc As NotesDocumentCollection
Dim doc As NotesDocument
Set uiview = ws.CurrentView
Set dc = uiview.Documents
Set doc = dc.GetFirstDocument
Dim unid_doc$
Dim dirname$
dirname$ = "c:" ’ default directory
Dim docsubject$
Dim docfile$
While Not (doc Is Nothing) ’ loop thru all selected docs
docsubject$ = doc.Subject(0) ’ get doc subject
docfile$ = Trim$(docsubject$ + “.ndl”) ’ use doc subject for default file name
’ format unid of doc
unid_doc$ = “OF” + Left$(doc.UniversalID, 8) + “:” + Mid$(doc.UniversalID, 9, 8)_
- “-ON” + Mid$(doc.UniversalID, 17, 8) + “:” + Right$(doc.UniversalID, 8)
’ open save dialog
filenames = ws.SaveFileDialog( False,"Save - " + docsubject$, dirname$, docfile$)
If Not(Isempty(filenames)) Then
If Dir$(filenames(0)) = “” Then ’ check if file already exists
’ if no then create doc link
fileNum% = Freefile()
Open filenames(0) For Output As fileNum%
Print #fileNum%, “”
Print #fileNum%, "<REPLICA " + repid_db$ + “>”
Print #fileNum%, "<VIEW " + unid_alldocs$ + “>”
Print #fileNum%, "<NOTE " + unid_doc$ + “>”
Print #fileNum%, “”
Close fileNum%
Else
’ if yes then ask to overwrite
Dim answer%
answer% = Messagebox(“File exists! Overwrite?”, 4+32, “Overwrite?”)
If answer% = 6 Then
Print #fileNum%, “”
Print #fileNum%, “”
Close fileNum%
dirname$ = Strleftback(filenames(0), "", 0, 1) ’ get directory for next file save
Set doc = dc.GetNextDocument (doc)
Wend
