Hi,In a computed field called fbadstk i have put below formula.This needs to get the result of Total qty - Good stk qty
if it gets a negative value it needs to throw a prompt and place 0 other wise the result of subtraction.It’s not working.I beleive code is incomplete.pls help
a:=@If(fqty1=“” | fgud1=“”;0;fqty1-fgud1);
@If(a<0;@Do(@Return(@Prompt([ok];“Validate”;“Gud stk shd be <than totqty”)));a);
a
