Subject: Problem with Passthru server - worked … then it didn’t - HELP!!
Just checking your settings:ServerPassthru, ServerA, serverB. A and B are not accessible from outside. PassThruServer has an external ip that translates to an internal ip.
In ServerPassthru security tab:
Route Through - list users\ groups that are allowed to pass thru ServerPassThru.
Destinations Allowed - list ServerA and ServerB (blank means, if you can pass thru, you can pass thru to any server).
In ServerA security tab:
AccessThisServer - list users\ groups who are allowed to access this server via passthru.
In ServerB security tab:
As for ServerA
In NAB on users remote PC\ laptop:
Connection doc 1 - Type : passthru, enter the passthru server (ServerPassThru) and the Destination (ServerA).
Connection doc 2 - as above except destination ServerB.
Make these connections only available to their “Internet” location, or whatever…, the Office location, I presume, does not need to know these exist.
Connection doc 3 - type LAN, TCPIP, PassThruServer, and the external ip on the advanced tab.
…and regular conection docs to ServerA, ServerB and PassThruServer.
I forget if the Notes Client caches the connections, restart Notes to be sure.
What happens with the trace?
To test, in Notes Client, goto “File\ Preferences\ User Prefs…”
Goto Ports Tab, push “Trace”…enter ServerA and Trace.
I have been using PassThru for ages now, we are actually turning it off 'cos we got a VPN installed.
I make sure that the remotes Notes client machines have port encryption on.
I’m off for the weekend, so I’ll see how you got on, next Monday.
Nick
