Hi there,
I have a strange problem with this mail db, but only on a full client with Designer &Admin.
OS is Win 10 (Details below)
Clients 12.0.1 FP1 -12.0.2 FP4
The problem is reproducable:
- Open Client
- Open Designer
- Open a db in the designer,
- Open mail -> empty mail frame,no content, Notes hangs
This only happens with the email database, all other DBs are not concerned.
Any ideas what going on in the mail db during start ?
Sincerly
Jochen "Joe" Herrmann
Edition Windows 10 Pro Version 22H2 Installiert am 06.03.2024 Betriebssystembuild 19045.4529 Leistung Windows Feature Experience Pack 1000.19058.1000.0
Prozessor 13th Gen Intel(R) Core(TM) i7-1355U 1.70 GHz Installierter RAM 32,0 GB (31,7 GB verwendbar) Systemtyp 64-Bit-Betriebssystem, x64-basierter Prozessor Stift- und Toucheingabe Für diese Anzeige ist keine Stift- oder Toucheingabe verfügbar.
Hi Joe
What access the user has on his mail file?
@Sudhakar Kunam
thanks for your reply.
2 persons and me = 3 User as Person/Designer
Kind Regards,
Joe
Hi Joe
Can you try below methods and share the results
1. Close Notes Client and Designer / Admin Clients and start only Notes Client
From Workspace, right click on the database and click on Open in Designer.
2. Temporarily change the access to Manager and check.
Regards
Hello @Sudhakar Kunam
1. Done, no problem. As long as the template of the mail db is open in the designer everything is ok.
2. Has no effect. It still hangs in the described situation
Either one keeps the mail DB open in the client or one keeps in the designer the DB open.
Kind Regards
Hello,
I think increasing JVM memory will help to avoid these issues.
Please open < Notes program dir>/framework/rcp/deploy/jvm.properties file and confirm the following parameters.
The following example shows the default values for 12.0.2.
vmarg.Xmx=-Xmx512m
vmarg.Xms=-Xms256m
vmarg.Xmca=-Xmca512k
vmarg.Xss=-Xss1m
If a value smaller than the above is set, it is recommended to increase it.
And I also recommend to clear cache files. Please refer to the "Troubleshooting steps: " section in the following KA.
- Guide to resolving various Notes problems
https://support.hcltechsw.com/csm?id=kb_article&sysparm_article=KB0102059
If it doesn't work, we need investigate more in detail. Please consider to open a support ticket.
Regards,
@Chiharu Sato
I verified the jvm.properties values you mentioned. Everything ok.
I deleted cache.ndk .
And still the same problem.
I will now try to debug the mail db when I open it. I think that there is something in the start procedure of the mail file that causes this problem, becasue its always only(!) a problem with the mail file..
If it is DOMI related I might not be able to debug it, but I can tell you guys at what point it stops.
Kind Regards
Joe
Hi Joe
Is this client 32 bit or 64 bit? If it is 64 bit, try opening with 32 bit client and let us know the results.
Regards
Sudhakar
@Sudhakar Kunam
it is the 32-bit client.
I have now changed the mail template to 12.0.2 (20.10.2022) and its still the same problem.
As a workaround I open now immediately when I open the designer the mail file in the designer. Then everything works. If I close the mail db in the designer and I close it in the client and then try to reopen the mail -> Bang !
I event tried to debug LS during the start phase of the mail and had to learn that the problem happens before the debugger window opens. Then the client & designer hang and when I press the x button, both windows disappear and ... the degugger window appears- Of course also blocked.
Our admins have now sent my notebook onto the Windows 11 upgrade tour. Was told it may take up to 2 hours. C u l8r
Kind Regards,
Joe
Hi Joe,
Good day.
Kindly do mail file maintenance on the affected mail db, you can see the steps below:
load fixup mail\databasename.nsf -F -J
load compact mail\databasename.nsf -c -D -I -K
load updall mail\databasename.nsf -R
I hope this helps.
Regards,
Ren Mark
Hi Joe,
If this is happening with single mail db and all other mail dbs are opening fine then there is some corruption in that mail DB and running maintenance should fix it. If your Designer Client is giving issues in opening all the mail dbs then it is the issue with that machine specific Designer Client. So please try Designer Client from a different machine and it should work fine. Open the Notes Client (in standard mode) before opening a Designer Client and then it open the Designer client more easily. Also from Designer Client, select "File > Close All" to close all the open databases and then open the specific mail db by going to File > Open > Application. If this is still not working then make sure that, Designer Client is in the same network as that of server. Sometimes if the network is slower then it gives problems in opening the database. I hope all this should help.
Thank you.
Hello @Sandeep Deshpande
the suggestion of Ren Mark Tapang solved this problem:
Tested it now several times and had no more problems.
There is another user with a designer client who ran into the same problem. I have told our admins to do the above to his mail file as well. After he's back from holidays he can verify his mail db.
Kind Regards
unfortunately I have got the problem again.
But now I am using Notes 12.0.2 FP4 , Windows 11 and the Mail template 12.0.2 (20.10.2022)
And(!) I am now in Home Office thus I am using a VPN. But problem is still only with the Mail DB.
Kind Regards,
Joe
Hi Joe,
It looks like your database is corrupt.
If you have any working replica of this database which is not having this issue, then you can later replace the affected db with the working good replica.
For now, you can still try the maintenance commands to get it fixed for time being.
If you do not have a backup of this database then it is highly recommended to take a safe backup since this database can go corrupt.
Thank you.
Hi there,
now teh DB isnot corrupt - that would solve the problem. :-)
Have now anoterh DB that hangs my Notes Client when opened at the "wrong" moment.
But there is one thing in common:
its also a mail db
Its a version 8.5 mail and my mail db is 12.0.2
Running on client/designer/admin 12.0.2 FP4
It does not happen while debugging or I have to debug the opening "ceremony" simply often enough :-)
Someone else ?
Kind Regards
Joe
Update:
Now i am using 12.0.2. FP5 and the problem persists.
Both mail dbs have the ability to hang the client and it happens before I have a chance to use the LS-Debugger.
As the second mail is used also by others i can say that they do not expierience this problems too.
I fear that I have to reinstall the client.
Oh, whats different too is that on my client Ytria is installed.
Kind regards,
Joe
What happens in the client when a mail db is opened?
Whenever the client is open and then i Open the designer and then I try to open my mail file, the client and the designer both hang. Pushing the X-Button often and long enough leads to a messagebox that says that the program does not answer ... highway to taskman hell ;-)
I can not debug it with the LotusScript debugger. If the mail file is open before the designer was opened then there is no problem as long as I do not close the mail. If I close the mail db and try to reopen it ... damned good chance the client and designer hang. I assume its around 50-60%.
It can't be a corrupt mail file because I have 2 mail files with this problem and one is a mail-in for a group and only I have this problem ! They work on clients 12.0.1 and it works without a problem. I have 12.0.2. FP5 and it hangs. The mail-in db is version 8.5 and my mail db is 12.0.2
It also works on my client as long as the designer is closed. I even had the mail file open once and tried to open the calender and ... client hanged.
Any Ideas ?
Kind Regards,
Joe
Hi there,
I am now on Notes 12.02. FP6 and Windows 11 Pro 23H2
The propblem persists.
This morning it killed my Working Sets ! The working sets exist but are empty. Have to move know every DB in the right working set.
This is really annoying !
Joe
