Does anybody ever use this C API function?
I just can’t make it work. It always crashes, no matter what kind of collection I pass here. Collection is already open, and I can retrieve data from it without any problems. I’m working with Lotus Domino database, C API SDK 6.5.3 is used.
Subject: Problem with NIFGetLastModifiedTime
just post the lines where you call this function. if it crashes its maybe just some pointer confusion?
Markus Seitz
markus.seitz@icodex.com
Unlock efficiency with BCC ClientGenie: a robust HCL Notes client administration solution. Streamline setup, troubleshooting, and complex tasks like upgrades. Optimize costs, lighten admin workload, and boost end-user productivity.
Subject: RE: Problem with NIFGetLastModifiedTime
There is absolutely nothing special in this function usage:
TIMEDATE dt = {0};
::NIFGetLastModifiedTime(hCollection, &dt);
hCollection is properly initialized in this code, because just before this code I read data from collection, and the data returned without errors.
I just want to see at least usage example, that works - I can’t understand what I am doing wrong.
Thanks.
i’ve just added these two lines to a part of source, right after NIFOpenCollection. it returned a valid timedate. (although documention is unclear and says its a sequence number).
maybe you’ve encountered a bug? sorry, i don’t know.
Markus Seitz
Thanks for the responce…
Do you work with local or server database?
OK, there are several lines of code:
STATUS lnRes = ::NIFOpenCollection(hViewDb, hDataDb, hViewNoteID, 0, NULLHANDLE, &m_hCollection, NULL, NULL, NULL, NULL);
if (NOERROR == lnRes)
TIMEDATE dtLastModif = {0};
::NIFGetLastModifiedTime(m_hCollection, &dtLastModif);
NIFGetLastModifiedTime still crashed in 100% of cases. I use C toolkit 6.5.3, Lotus Notes 6.5 and Domino server 6.5, database is located on the server.
What I’m doing wrong?
i’ve tried it with a local db only.
one more thing: you should get a nsd-report. feel free to send it to me, i’ll have a look.
Markus Seitz
