Problem with mail85.ntf and mailjrnl.ntf after installing multiple language packs
After installing 12 language packs on a 8.5.1 Server, I am no longer able to replace my design on that server. I get the error: Mail Convert Failed on mail\xxxxxxxx.nsf: Design Replacement Error: Memory allocation request exceeded 65,000 bytes
No customisations were made to the template, this is just the standard template with the different language design elements added to it.
Any ideas?
Subject: Re: problem with mail85.ntf and mailjrnl.ntf after installing multiple language packs
Hi
I get the same error, server is 8.5.1FP3 and I have about 10 language packs installed.
Did you ever get a fix or is this issue still outstanding?
Dave
Subject: confirmed as a bug
IBM proposed to use multiple templates with other languages as a workaround. Won’t be much help when using webmail though.
