Problem with Lotus traveller 8.5.1
Hello,
I got this error message during initialization of TravelerServlet:
HTTP JVM: com.lotus.sync.servlet.TravelerServlet: init
HTTP JVM: Exception caught while trying to access NTS server settings during refresh. Server data was not refreshed. Exception Thrown: java.lang.NullPointerException
HTTP JVM: java.lang.NullPointerException
HTTP JVM: at com.lotus.sync.admin.NTSSettingsINI.refreshSettings(NTSSettingsINI.java:773)
HTTP JVM: at com.lotus.sync.admin.NTSSettingsINI.alarmCallback(NTSSettingsINI.java:1203)
HTTP JVM: at com.lotus.sync.admin.NTSSettingsINI.initialize(NTSSettingsINI.java:238)
HTTP JVM: at com.lotus.sync.servlet.TravelerServlet.init(TravelerServlet.java:384)
Does any know what is all about?
thnx in advance,
Dragan
Subject: RE: Problem with Lotus traveller 8.5.1
Generally you will see something like this if Traveler can not find the server document. Check these notes.ini settings to be sure they are correct:
ServerName=
Domain=
If those are correct then I recommend opening a problem report with Lotus support to better troubleshoot.
