Problem with ListTag re ForAll with list held in a Field
My code snippet:
Forall x In doc.VoteVoter
If x = “01 John Smith” Then
Print Listtag(x)
End Forall
I get the error: LISTTAG argument not a list element
If I simplify down to:
Print Listtag(x)
End Forall
I still ge the same error message.
doc.VoteVoter contains:
(0) “01 John Smith”
(1) “02 John Smith”
Subject: Problem with ListTag re ForAll with list held in a Field
doc.VoteVoter is not a list, so you cannot use x as list tag.(it can be a bit confusing: the item type is a list, but the data type is an array)
You can use:
Print x
End Forall
The values in the field are not a List (as defined by LotusScript), they are just multi-values
You will need to set a NotesItem, do a Forall x in item.Values and then within the forall, do some string manipulation to get the “01” part separate from the “John Smith” part
why you trying list?
