I´m programing an agent, this agent write in a database in Postgres in a pc linux CentOs 4.0,the domino server is install in this pc, the agent use the library Uselsx “*LSXODBC” because i am using an odbc for accesing to the database, the agent run very good in a notes client under windows, but when i programing a schelude in the domino server give me an error when the agent run, can´t chage the library “*LSXODBC”, how can i solve this problem please…
Subject: Problem with library Uselsx “*LSXODBC” in linux
I never tried it myself, but it looks like it should work when configured properly… at least on some Linux versions.
Take a look at these articles and search in this forum and on Google for “lsxodbc linux”.
ODBC does not run under Linux. You can use JDBC instead.
From the command line, try “locate lsxodbc” and check that the lsxodbc library is installed. We have two lsxodbc files…
/opt/lotus/notes/65040/linux/liblsxodbc.so
/opt/lotus/notes/65040/linux/res/C/lsxodbc.res
The location of these might vary depending on your version, and install location, but I guess they should be there somewhere!
You also probably need to set up the odbc.ini file, which is normally in the /etc/ directory. This is where you can set up the host name, access type etc., that you are using in your agent.
Hope this helps a bit,
Craig.
Subject: RE: Problem with library Uselsx “*LSXODBC” in linux
I had this error and got it solved after following the guidelines in the redbook 246835 Lotus Domino 6 for Linux:
$ cd /opt/lotus/notes/latest/linux
or wherever path your lotus domino is installed
$ ln -s /usr/lib/libodbc.so
Of course you must have already installed unixODBC and completed setup the odbcinst.ini and odbc.ini
