Problem with install Domino 6.0.1 on Solaris
Hi all.I was tried to install Domino R6.0.1 on Solaris and I had the following error.
"An unexpected error occured during post-install processing:
Died at (eval 33) line 35.
/export/home4/group/sysadm/Domino/sol/tools/lib/NIC.pm line 963
The installation failed for the local host."
I’ve installed 108434-03 patch and made
the following changes in the /etc/system file on the Solaris 8.
set rlim_fd_max=32768
set msgsys:msginfo_msgtql=1024 (rquirements for Domino 6.0.1 on Solaris)
Thanks in advance.
Regards,
Adam Wojcicki
Adam.Wojcicki@nom1044.pl
Subject: Problem with install Domino 6.0.1 on Solaris
Hi all. I’ve the same probleme on a Solaris 2.8 / Netra T1. All parameters seems ok (RAM, Hard Drive and so on…) but i had the following error :
An unexpected error occured during post-install processing :
Died at (eval 34) line 2
…propagated at (eval 33) line 328
/ibm1/upDomino/sol/tools/lib/NIC.pm line 930
I warned lotus support. I’ve no answer for the moment…
Frederic Jacquet
PS: of course i was connected with root account. All parameters (patches and so on) seems to be good…
Did you install it as root ?
Hi Adam!
Some configuration settings may cause such behaviour. All my installations were good, but in one environment I’ve experienced the same problem. I made wrong. I was reinstall whole system, after few failed attempts to install 6.0.1. Now I want to make comparison.
I have some ideas about it, and wrote you by e-mail.
