Problem with generate unique keys in index
hello
How can I filter documents whith same value in a field with another method?, becasue “generate unique keys in index” in view properties doesn´t work"
please help me,
Subject: Problem with generate unique keys in index
What do you mean it doesn’t work? Or better yet, what are you trying to achieve?
The generate Unique keys in index will cause a sorted (or categorized) view to show multiple values only once. Is this the functionality you are looking for?
Cheers,
Mark
Subject: RE: Problem with generate unique keys in index
Hi Mark,
I need to show multiple values only once in to the view.
thanks
Hey Green,
The generate unique keys in index should do it for you then. what are you seeing? Make sure that the keys are actually unique. Views don’t always show all the details. Check the doc properties for the field values to unsure that the data is the same if you are seeing more than one entry per key. Often date fields cause trouble in keys cause one doc may have just a date and another may share the same date but have a time component etc. this will make the keys different.
I have also notice problems when there is a rep or save conflict in the view.
Good Luck and Cheers,
Mark
