Hi to everyone i have a problem.I have a richtext field where i must import a mail, but i can’t import also the file that are attached to the mail. How can i do?
I would like to do this by lotus script.
Can someone help me?
Thank you a lot!
Thank you a lot!
Subject: Problem with detach file from Memo document with LS
The easiest way, if your requirements are flexible enough, is to create a new notesdocument and then use CopyAllItems to copy everything from the memo to your new document.
Then, add/change/delete fields on the new doc before saving it for the first time.
Subject: RE: Problem with detach file from Memo document with LS
The problem is that i must copy the attachment in the same open document in which i import the mail.
Can you help me in this way?
