Hi everyone,
I have a problem with Community Templates in Component Pack 7.0.0.2.
I can't create Templates. I can isolate the Problem to the WebSphere Application "IC360_mod_template". When creating a Template I get a 500 error message from "/comm-templates/" which points to CP. In the logs of the pod there is an error pointing to ICXT with a wrong JSON response.
In the "SystemOut.log" of the ICXT Cluster is the following message:
[5/19/21 11:45:00:193 CEST] 00000123 webapp I com.ibm.ws.webcontainer.webapp.WebApp log SRVE0292I: Servlet Message - [IC360_mod_template#ic360.mod.template.war]:.Initializing Spring FrameworkServlet 'ic360.mod.template'
[5/19/21 11:45:00:195 CEST] 00000123 DispatcherSer I org.springframework.web.servlet.FrameworkServlet initServletBean FrameworkServlet 'ic360.mod.template': initialization started
[5/19/21 11:45:00:196 CEST] 00000123 DispatcherSer E org.springframework.web.servlet.FrameworkServlet initServletBean Context initialization failed
org.springframework.beans.factory.CannotLoadBeanClassException: Error loading class [com.ibm.ess.ic.ic360.mod.template.api.ActivitiesTemplateAPIController] for bean with name 'activitiesTemplateAPIController' defined in file [/opt/IBM/WebSphere/AppServer/profiles/AppSrv01/installedApps/swConnectionsCell/IC360_mod_template.ear/ic360.mod.template.war/WEB-INF/classes/com/ibm/ess/ic/ic360/mod/template/api/ActivitiesTemplateAPIController.class]: problem with class file or dependent class; nested exception is java.lang.LinkageError: loading constraint violation when overriding method "com/ibm/ess/ic/ic360/webapp/AbstractIc360Servlet.getLogger()Lorg/slf4j/Logger;" during creation of class "com/ibm/ess/ic/ic360/mod/template/api/ActivitiesTemplateAPIController": loader "com/ibm/ws/classloader/CompoundClassLoader@f98e3ea0" of class "com/ibm/ess/ic/ic360/mod/template/api/ActivitiesTemplateAPIController" and loader "com/ibm/ws/classloader/CompoundClassLoader@c8e86dd8" of class "com/ibm/ess/ic/ic360/webapp/AbstractIc360Servlet" have different types for the method signature
at org.springframework.beans.factory.support.AbstractBeanFactory.resolveBeanClass(AbstractBeanFactory.java:1360)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.determineTargetType(AbstractAutowireCapableBeanFactory.java:628)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.predictBeanType(AbstractAutowireCapableBeanFactory.java:597)
at org.springframework.beans.factory.support.AbstractBeanFactory.isFactoryBean(AbstractBeanFactory.java:1450)
at org.springframework.beans.factory.support.AbstractBeanFactory.isFactoryBean(AbstractBeanFactory.java:980)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:755)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:861)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:541)
at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:444)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:326)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:107)
at com.ibm.ws.webcontainer.webapp.WebApp.notifyServletContextCreated(WebApp.java:1743)
at com.ibm.ws.webcontainer.webapp.WebAppImpl.initialize(WebAppImpl.java:415)
at com.ibm.ws.webcontainer.webapp.WebGroupImpl.addWebApplication(WebGroupImpl.java:88)
at com.ibm.ws.webcontainer.VirtualHostImpl.addWebApplication(VirtualHostImpl.java:171)
at com.ibm.ws.webcontainer.WSWebContainer.addWebApp(WSWebContainer.java:904)
at com.ibm.ws.webcontainer.WSWebContainer.addWebApplication(WSWebContainer.java:789)
at com.ibm.ws.webcontainer.component.WebContainerImpl.install(WebContainerImpl.java:427)
at com.ibm.ws.webcontainer.component.WebContainerImpl.start(WebContainerImpl.java:719)
at com.ibm.ws.runtime.component.ApplicationMgrImpl.start(ApplicationMgrImpl.java:1211)
at com.ibm.ws.runtime.component.DeployedApplicationImpl.fireDeployedObjectStart(DeployedApplicationImpl.java:1464)
at com.ibm.ws.runtime.component.DeployedModuleImpl.start(DeployedModuleImpl.java:642)
at com.ibm.ws.runtime.component.DeployedApplicationImpl.start(DeployedApplicationImpl.java:1042)
at com.ibm.ws.runtime.component.ApplicationMgrImpl.startApplication(ApplicationMgrImpl.java:795)
at com.ibm.ws.runtime.component.ApplicationMgrImpl.startApplicationDynamically(ApplicationMgrImpl.java:1413)
at com.ibm.ws.runtime.component.ApplicationMgrImpl.start(ApplicationMgrImpl.java:2273)
at com.ibm.ws.runtime.component.CompositionUnitMgrImpl.start(CompositionUnitMgrImpl.java:436)
at com.ibm.ws.runtime.component.CompositionUnitImpl.start(CompositionUnitImpl.java:123)
at com.ibm.ws.runtime.component.CompositionUnitMgrImpl.start(CompositionUnitMgrImpl.java:379)
at com.ibm.ws.runtime.component.CompositionUnitMgrImpl.access$500(CompositionUnitMgrImpl.java:127)
at com.ibm.ws.runtime.component.CompositionUnitMgrImpl$1.run(CompositionUnitMgrImpl.java:654)
at com.ibm.ws.security.auth.ContextManagerImpl.runAs(ContextManagerImpl.java:5536)
at com.ibm.ws.security.auth.ContextManagerImpl.runAsSystem(ContextManagerImpl.java:5662)
at com.ibm.ws.security.core.SecurityContext.runAsSystem(SecurityContext.java:255)
at com.ibm.ws.runtime.component.CompositionUnitMgrImpl.startCompositionUnit(CompositionUnitMgrImpl.java:668)
at com.ibm.ws.runtime.component.CompositionUnitMgrImpl.startCompositionUnit(CompositionUnitMgrImpl.java:612)
at com.ibm.ws.runtime.component.ApplicationMgrImpl.startApplication(ApplicationMgrImpl.java:1303)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:90)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:55)
at java.lang.reflect.Method.invoke(Method.java:508)
at sun.reflect.misc.Trampoline.invoke(MethodUtil.java:83)
at sun.reflect.GeneratedMethodAccessor88.invoke(Unknown Source)
at sun.reflect.misc.MethodUtil.invoke(MethodUtil.java:287)
at javax.management.modelmbean.RequiredModelMBean$4.run(RequiredModelMBean.java:1263)
at java.security.AccessController.doPrivileged(AccessController.java:664)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:91)
at javax.management.modelmbean.RequiredModelMBean.invokeMethod(RequiredModelMBean.java:1257)
at javax.management.modelmbean.RequiredModelMBean.invoke(RequiredModelMBean.java:1096)
at com.sun.jmx.interceptor.DefaultMBeanServerInterceptor.invoke(DefaultMBeanServerInterceptor.java:831)
at com.sun.jmx.mbeanserver.JmxMBeanServer.invoke(JmxMBeanServer.java:813)
at com.ibm.ws.management.AdminServiceImpl$1.run(AdminServiceImpl.java:1351)
at com.ibm.ws.security.util.AccessController.doPrivileged(AccessController.java:118)
at com.ibm.ws.management.AdminServiceImpl.invoke(AdminServiceImpl.java:1244)
at com.ibm.ws.management.connector.AdminServiceDelegator.invoke(AdminServiceDelegator.java:181)
at com.ibm.ws.management.connector.ipc.CallRouter.route(CallRouter.java:247)
at com.ibm.ws.management.connector.ipc.IPCConnectorInboundLink.doWork(IPCConnectorInboundLink.java:360)
at com.ibm.ws.management.connector.ipc.IPCConnectorInboundLink$IPCConnectorReadCallback.complete(IPCConnectorInboundLink.java:602)
at com.ibm.ws.ssl.channel.impl.SSLReadServiceContext$SSLReadCompletedCallback.complete(SSLReadServiceContext.java:1833)
at com.ibm.ws.tcp.channel.impl.AioReadCompletionListener.futureCompleted(AioReadCompletionListener.java:175)
at com.ibm.io.async.AbstractAsyncFuture.invokeCallback(AbstractAsyncFuture.java:217)
at com.ibm.io.async.AsyncChannelFuture.fireCompletionActions(AsyncChannelFuture.java:161)
at com.ibm.io.async.AsyncFuture.completed(AsyncFuture.java:138)
at com.ibm.io.async.ResultHandler.complete(ResultHandler.java:204)
at com.ibm.io.async.ResultHandler.runEventProcessingLoop(ResultHandler.java:775)
at com.ibm.io.async.ResultHandler$2.run(ResultHandler.java:905)
at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1892)
This seems to be the main problem. I tried experimenting with Calls loading in WebSphere but that didn't solve the problem.
Has anybody had a similar problem?
Regards
Florian
