Problem with @Command([AttachmentView])
I have problem with @Command([AttachmentView])
iam using this in adocument which is opened in edit mode.It is prompting an error message"Can not execute the specific command "
.Before using this action I selected the attachment in the field.
Thanx in advance
Subject: Problem with @Command([AttachmentView])
If the code is in a hotspot, then the process of clicking on the hotspot will deselect the attachment.
You could try putting the code in an action button, or adding an [EditGotoField] and [EditSelectAll] commands prior to your [AttachmentView].
HTH - Rufus.
