Problem with array
I’m trying to build an array by adding values from a number of selected documents. When I step through the code and watch the debugger I can SEE the array getting filled in with values from each document. But when I try to output the contents I get null. I’ve added a Print line and it outputs nothing.
Here is the code:
Set collection = db.UnprocessedDocuments
iCount = collection.Count
Redim varUnlinked(iCount-1) As Variant
	Set doc = collection.getFirstDocument()
	i=0
	Do Until doc Is Nothing
		varUnlinked(i) = doc.GetItemValue("ProjectRef")
		Print varUnlinked(i)
		i = i +1
		Set doc = collection.getNextDocument(doc)
	Loop
What am I doing wrong?
Subject: Problem with array
Try this varUnlinked(i) = doc.GetItemValue(“ProjectRef”)(0)
or
Try Redim Preserve
I’m not sure why you’re using Variant as the DataType for your array,… Search the Designer help for “Dynamic Array” there’s an article there with examples of how they do it.
Edit: I thought of this code… test it and let me know if that works:
Dim iCount as Integer
Dim counter as Integer
Dim varUnlinked as String
Redim varUnlinked(iCount)
For i = 1 to iCount
Set doc = collection.GetNthDocument(i)
Next
Subject: RE: Problem with array
You suggestion yields “Illegal parenthesized reference: VARUNLINKED”
Sorry, I had a % after iCount that I removed… try to copy/paste the code again.
Also I showed the Dim statement for the variables I’m using in the code, but not what you were using outside of it… make sure you declared every datatype properly. I can’t see it cause you didn’t paste the whole code.
Subject: Problem solved
I found the problem. GetItemValue returns an Array, so I was trying to load my varUnLinked array with another array. I fixed it by extracting the value of the array before loading my varUnlinked array. Here is the working code:
Sub Initialize
Dim collection As NotesDocumentCollection
Dim db As NotesDatabase, doc As NotesDocument
Dim i As Integer, iCount As Integer
Dim varUnlinked() As Variant , vProjRef As Variant
If iCount <=1 Then
	Msgbox "You must select 2 or more Projects to create Linking",0,"Error"
	Exit Sub
Else
	i=0
		vProjRef = doc.GetItemValue("ProjectRef")
		varUnlinked(i) = vProjRef(0)
		i = i +1
	Loop
i=0
For i =0 To Ubound(varUnlinked)
Next
Subject: RE: Problem solved
GetItemValue will indeed always return an array, so will the ‘shortcut’ method of doc.NameofItem.
In both cases you can avoid the hassle of storing it it a variant and then extracting the first value:
… or …
varUnlinked(i) = doc.ProjectRef(0)
