Problem with a loop
I need to get some properties from all Notes databases on a particular server. At the moment I have a loop that successfully runs through the first few hundred databases and then crashes with “Object variable not set”. I have debugged the code and the script is unable to set db. I cannot find any problems with the db that the database fails on.
Dim curdoc As NotesDocument
Dim db As NotesDatabase
Dim directory As NotesDbDirectory
Dim template As String
Dim collection As NotesDocumentCollection
Set curdb = s.CurrentDatabase
Set directory = New NotesDbDirectory("Notes01")
Set db= directory.GetFirstDatabase( DATABASE )
Do Until db Is Nothing
	Set db = directory.GetNextDatabase()
	Print db.FilePath
Loop
Subject: Problem with a loop
Hi Alice,
You need to swap 2 lines of code- when the “Loop” hits the last database, you are still looking for one more, and it doesn’t exist.
Set directory = New NotesDbDirectory(“Notes01”)
Print db.FilePath
Loop
Subject: RE: Problem with a loop
Yes
But, I do prefer the ‘while loops’, because my teachers told me it is better. lol
ian
Does directory contain an object, or is it nothing ?
	Print db.FilePath
Loop
which is not particulary smart… :wink:
you should write :
while not db is nothing
print db.filePath
wend
ian
Thanks for your response.
I have tried using wend and moving the getnextdatabase line and the script still fails.
I have also tried this on other servers and get the same problem
Rgds
What is your final source ?
