Hello,
I created a java agent which load specific library.
I added .jar to the project by clicking the Edit Project
button and browsing to the directory where the file is located and I put dll file into C:\Lotus\domino.
I ran my agent (by web page) and it works well the first use but now, I’ve an error !
HTTP JVM: java.lang.UnsatisfiedLinkError: Native Library C:\Lotus\Domino\pdf_java.dll already loaded in another classloader
I don’t know what happen !
I tried to put .jar and .dll into C:\Lotus\domino but always the same error…
It’s the first time that I use java in notes and my knowledge is not very big (as my english ^^')
Thanks for your help
Vincent
Subject: Problem with a Java agent : classloader
http://www-10.lotus.com/ldd/nd6forum.nsf/7524faba161e725085257050006f194c?OpenForm&ParentUNID=670305247B89F1C18525758900509FEA
I have found a Technote about your issue 1114724 :
Error: “db2jdbc.dll Already Loaded in Another Classloader” Running Java Agent
Technote (FAQ)
Problem
A Java agent is written to use the DB2 JDBC or another JDBC driver to access a database. When it is initially run the agent may work, however, subsequent attempts to run the agent fail with the following error:
"java.sql.SQLException: java.lang.UnsatisfiedLinkError: Native Library C:\SQLLIB\BIN\db2jdbc.dll already loaded in another classloader."
Solution
In order for a Java agent to successfully use this driver a second time, the .dll should be added to the Notes program directory.
In this case, the agent was being run manually from a client. The DB2 client was loaded in C:\SQLLIB\BIN. The Notes client was located in C:\Lotus\Notes. Copying the db2jdbc.dll from C:\SQLLIB\BIN to C:\Lotus\Notes resolved the problem.
I hope that this help you
