Problem whit Lists?
Hello!
Lotus 6
@Formula
I have some trobles whit my this formula!
I want to sum the values from list field artsave2 to list field wert1!
And I have made the following formula!
Field artsave2 has following values:
1,49~2;
1,99~4;
1,99~6;
2,99~8;
2,99~9;
Field wert1 has this values:
1,29~0;
1,49~0;
1,39~0;
1,59~0;
1,80~0;
1,99~0;
2,19~0;
2,50~0;
2,75~0;
2,79~0;
2,81~0;
2,99~0;
3,29~0;
3,49~0
@For(n := 1;
n <= @Elements(artsave2);
n := n + 1;
imp1:= @Subset (@Subset (artsave2; n); -1);
imp2:= @Word(imp1;“~”;2);
Memb := @Member(@Word(imp1;“~”;1);@Word(wert1;“~”;1));
Preis :=@Word(@Subset (@Subset (wert1; Memb); -1);“~”;1);
Zahl1 := @Word(@Subset (@Subset (wert1; Memb); -1);“~”;2);
ZahlNeu := @TextToNumber(Zahl1) + @TextToNumber(imp2);
WertNeu:= @Text(Preis) +“~” + @Text(ZahlNeu);
Subset1:=@Subset(wert1;memb -1);
elements := @Elements(wert1) - memb;
Subset2:= @Subset(wert1; - elements);
wert2 := subset1 : subset2 : WertNeu;
@Sort(@Word(wert2;“~”;1));
FIELD wert1 := Wert2
But it doesn´t work!
I want to have the following result
1,29~0;
1,49~0;
1,39~0;
1,59~0;
1,80~0;
1,99~10;
2,19~0;
2,50~0;
2,75~0;
2,79~0;
2,81~0;
2,99~17;
3,29~0;
3,49~0
What can I do!
Thank you for helping!
mfg
Jörg
Subject: Problem whit Lists?
I created a form.
One field is named ‘artsave2’ and has this default value: “1,49~2” : “1,99~4” : “1,99~6” : “2,99~8” : “2,99~9”
Another field is named ‘wert1’ and has these default values: “1,29~0”:“1,49~0”:“1,39~0”:“1,59~0”:“1,80~0”:“1,99~0”:“2,19~0”:“2,50~0”:“2,75~0”:“2,79~0”:“2,81~0”:“2,99~0”:“3,29~0”:“3,49~0”
Note that both field has semi-colon only specified as separator, definitely not comma.
I then created a 3rd field and named it ‘SumUpped’, also multi-value and using semi-colon only as separator.
A button in the form has this code:
newSum := “”;
@For (ix := 1; ix <= @Elements(wert1); ix := ix + 1;
leftPartIx := @Left(wert1[ix]; "~");
rightPartIx := @Right(wert1[ix]; "~");
curSum := @TextToNumber(rightPartIx);
@For (jx := 1; jx <= @Elements(artsave2); jx := jx + 1;
	leftPartJx := @Left(artsave2[jx]; "~");
	rightPartJx := @Right(artsave2[Jx]; "~");
	@If (leftPartJx = leftPartIx; curSum := curSum + @TextToNumber(rightPartJx); "")
newEntry := leftPartIx + "~" + @Text(curSum);
newSum := newSum : newEntry
@SetField(“SumUpped”; @Trim(newSum))
It seems to work fine.
Subject: RE: Problem whit Lists?
Hello!
Thank you for your help, thats realy great
but I cannot use unfortunately List, since application is to run also on a PocketPC!
Is there a way to make this wiht out the list syntax?
Thank your for helping!
Jörg
Hello!
I change your formula to this and it works fine!
Thank you very mutch!!
newSum := “”;
leftPartIx :=@Word(@Subset (@Subset (wert1; ix); -1);“~”;1);
rightPartIx := @Word(@Subset (@Subset (wert1; ix); -1);“~”;2);
leftPartJx :=@Word(@Subset (@Subset (artsave2; jx); -1);“~”;1);
rightPartJx := @Word(@Subset (@Subset (artsave2; jx); -1);“~”;2);
@If (leftPartJx = leftPartIx; curSum := curSum + @TextToNumber(rightPartJx); “”)
newEntry := leftPartIx + “~” + @Text(curSum);
sy
jörg
Nice work Ken! I was just gonna try and tackle this but you beat me to it.
