Problem while creating a Calender View
While creating calender view, what does the following mean-Create a second column or click the second column of the existing view. The second column must map to a field or formula on the document that specifies, in minutes, the duration of the event and it should be hidden
Subject: Problem while creating a Calendar View
It means that the second column in a calendar view must be a numeric value, with the duration of the event in minuets. And if you don’t want the users to see it, mark it as hidden.
Subject: RE: Problem while creating a Calendar View
But what does duration of the event mean? Which event are you talking about?
This is a calendar view so the events are calendar entries that last a specific period of time (possibly 0 minutes if it’s just a reminder of course).
Like a meeting that lasts 1 hour for example (60 minutes!)
Dan
