Problem when uploading ID file to Vault with Admin Client 14.x to Domino 12.0.1.x
Today I had the problem that a customer complained about the problem of uploading the ID of a new registered user to an existing vault. I could see the following entries in the local log.nsf:27.08.2024 11:03:00 ID 'C:\HCL\Notes\Data\user\testuser1.id' failed to upload to vault 'O=customer_vault' on server 'CN=SERVER01/O=SRV'. 'Test User1' made request. Error: Remote system no longer responding After opening a case I received the link to a TechNote where a problem with Admin Client V14.x and HCL Domino 12.0.1.x is documented. I afterwards modified the setting in the NOTES.INI of the client and now the upload of the ID for the newly registered user is working fine !!! Be aware to put the setting “TCPIP=TCP,0,15,16000” only in the NOTES.INI of a V14 client !!! If you set this value in a NOTES.INI of V12, the client will not startup and will cause serious troubles !!!
This is a companion discussion topic for the original entry at https://brandlrainer.info/2024/08/27/problem-when-uploading-id-file-to-vault-with-admin-client-14-x-to-domino-12-0-1-x/
