Hello
When I try to install my language pack, I’ve got this error:
Language Pack has successfully checked Domino
Information.
The Domino server version is 65040. The Lotus
Domino Language Pack Installer supports version
Release 6.5.4 (Release 6.5.4|March 27)
Please upgrade this server to the supported
version, then restart the Lotus Domino Language
Pack Installer. Please check LPLog.txt for
details…
[B]ack or [C]ancel [C]:
The server has been updated from version 5.11 whitout any problem.
thank for help
Christophe
Subject: Problem when installing Laguage Pack Fr
Hai,
I had the same Problem today - with the IBM Support I found the following error:
In this particular case, the Langauge Pack installed correctly after changing the state of the IOCP susystem from “Defined” to “Available”
root@host:/opt/lotus >lsdev -Cc iocp
iocp0 Defined I/O Completion Ports
After making iocp available, the language pack installed correctly:
root@host:/opt/lotus >mkdev -l iocp0
iocp0 Available
iocp0 Available I/O Completion Ports
Additional comments:
If the server had been started (set up) before installing the language pack, it would have shown errors of the type:
"Warning: Your system is not configured with I/O Completion Ports.
I/O Completion Ports must be installed in order to run the Domino 6 Server.
Install and make available I/O Completion Ports and restart your system."
Domino 6 requires I/O completion ports to be available.
Related Technote: 1086556
Stefan
