Under one specific situation, if a view is modified in Designer then I click the “X” button on the tab to close the view, it immediately closes then the “Do you want to save your changes” prompt appears and clicking Cancel has no effect - the view is closed regardless.
So far, I’ve only seen this odd behaviour if the following is true:
the view selection type is “Formula” (the “Simple Search” option produces correct behaviour);
I have made a change to the selection formula, and that is the only change made; and
the focus is in the selection-formula pane when I click the X button.
Correct behaviour is produced (i.e. the view remains open until the user clicks either Yes or No on the “Do you want to save your changes” prompt) if any additional changes have been made to the view, or if I move the focus away from the formula pane before clicking the X button.
Also, I have not seen the problem with any other type of design element.
