Problem using ADSync in domino
Hello!
I am using ADSync in domino.It is synchronizing perfectly when i create the new user either on domino or on MS Active Directory server.
For all the existing users on both domino and AD, i simply sync the user from AD to Domino (as there is option to sync the user with domino).
Now the problem is when i tired to rename any old user either from domino or from AD it gave the error in domino “Error processing certificate created by /Ucorp for User/Ucorp: The signature on the certificate was found to be invalid. Check the log file for details”.
Can anyone help me out in this regard?
Subject: Where is the error?
does this error happen in the admin client/ADSync or on the domino server console? Depending on the answer to that, have you checked the admin client or domino server log.nsf?
Subject: The error is
The error is “Error processing certificate created by Server/Ucorp for User/Ucorp: The signature on the certificate was found to be invalid. Check the log file for details” and displayed on the domino console.I checked the log file both on the server as well as in domino client but not found any clue
