HelloI want to mark one or more documents in a view, and export any files to a predetermined location on the server. What happens is that if i choose more than one document, so nothing is exported. What am I missing.
Sub Initialize
Dim session As NotesSession
Dim db As NotesDatabase
Dim dc As NotesDocumentCollection
Dim doc As NotesDocument
Dim body As NotesRichTextItem
Set session = New NotesSession
Set dc = db.UnprocessedDocuments
Set doc = dc.GetFirstDocument
If Not doc.HasEmbedded Then Exit Sub
Set body = doc.GetFirstItem("Body")
REM Get attachments
Forall att In body.EmbeddedObjects
If att.Type = EMBED_ATTACHMENT Then
filepath$ = "C:\temp\export\" & att.Source
Call att.ExtractFile(filepath$)
Print filepath$ & " extracted"
End Forall
I have tweaked your code for exporting attachments from the multiple documents. here it is…
Sub Initialize
While Not doc Is Nothing
Set body = doc.GetFirstItem("Attach")
cnt=cnt+1
End Forall
Set doc=dc.GetNextDocument(doc)
Wend
On Error Goto ErrorBlock
filepath$ = "C:\temp\" & att.Source
End Forall
Wend
Exit Sub
ErrorBlock:
Msgbox "Error is:" & Error() & " Error At:" & Erl
and one more thing is check if the Agent Second tab properties for set runtime security level as third option.
